Degradation >> Stability Analysis Column Switcher
What inspired this wish list request? Please describe the current issue that needs improvement or the problem to be solved that is not easy or possible right now, with an example use case. The column switcher isn't always available and when it is available (specifically when using a "by" variable it does not update the spec limits when switching between stability parameters
What is the improvement you would like to see? Please describe the idea for improving JMP. Please include mock-ups, wireframes, screenshots, scripts, other documents or examples from other software that help describe the change you would like to see. It would be great to use the column switcher when running stability with or without a by variable and have it rerun the analysis based on the correct specs in the column properties.
Why is this idea important? Please describe the value to you and/or other users if the idea is implemented (for example, ease of use, must have,…). Currently have to create a script for every parameter of the stability program (14+ parameters) for each product in our pipeline it also makes it difficult to easily bulk export the information into a single document. it would be a huge timesaver to utilize a column switcher and add a journaling script to automate this process as can be done for other platforms.
