Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
In the fit curve platform the option to have a inverse prediction is not available for quadratic models. It would be nice to add it. Of course if possible to include cubic and others it would be top.
@friedrich thank you for your suggestion. I have a follow up question. With a quadratic or higher order polynomial model, there is a possibility that that the fitted function will not be monotonic, and for a given Y value there could be two possible inverse solutions. How would you propose that situation be handled?
@SamGardner , would it be possible to have both solutions in the output ? Or the user may choose before if he wants the result for the 1st or 2nd solution ?
