Exporting Trees produced by hierarchical clustering
I want to export the specifications of trees I've made using hierarchical clustering (Analyze/Cluster...) in NEXUS format so I can manipulate them with a phylogenetics program like FigTree; i.e rooting, visualization, etc.
Using JMP 16Pro
3 Comments
Sarah-Sylvestre
Level V
Hi @cwcarterjr, thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
Hello @cwcarterjr .  Thank you for your idea and patience as we work through our backlog of wish list requests.
Could describe the problem you want to solve with this feature and why it is important to you?
Also, if you could provide a data example and a reference to the NEXUS format, that would be helpful.
Sarah-Sylvestre
Level V
