JMP Wish List
Custom Time/Date Format Pattern: history
There is a plethora of posts in the Jmp Community concerning Date and Time data curation, e.g.
Manipulating Timestamp
Unix Timestamp to Real Date & time
Changing Date Format
Date-Time Format Problem
Date Format help please
change date format
There are some tools which help a lot - but any improvement will help :)
For time & date columns the user can select from a long list of standard settings and even specify a custom pattern.
BuiltIn presets can be concatenate to construct the desired pattern.
Unfortunately, every time the user has to construct a pattern he has to start from scratch.
Please add a history to the custom date/time pattern dialog window.
Why is this idea important?
If a user uses a pattern once, there is a large chance that he will use it again.
With the history aavailable in the dialog window, it will be much easier to use the Format Pattern window:
Invest the time once to generate the pattern and enjoy it for the rest of your live.
2 Comments
Level XIII
@Sarah-Sylvestre , could you please check the status.
is it still "new"?
Sarah-Sylvestre
Hello, thank you for reaching out about this request. We have reviewed it and updated the status accordingly.
