JMP Wish List
Create a Vlookup function
Support,
I found a way to create a vlookup through scripting in JSL, but is there a possibility to include something like this in the formula editor under the Comparison menu?
Thanks for your consideration to this idea.
Ana Maria Heilman-Morales
4 Comments
mark_anawis
Hi Ana, Have you tried "Match"? If you select the column name first and single-click on "Match", it shows you a submenu where you can automatically add the Match arguments from the data (i.e. the values in your column). Then you can add the value you want returned in each then clause.
Jeff_Perkinson
Community Manager
Status changed to: Already Offered
There are many ways to get the same kind of result as VLOOKUP depending on your ultimate goal:
  • Virtual Join links a main data table to one or more auxiliary data tables
  • Tables->Join will add a column of values based on matching values
  • The Match function will compare values to a list and return a result
There are lots of other ways, again, depending on your need.
Ryan_Gilmore
Community Manager
Status changed to: Delivered
BHarris
We use the Table -> Update feature for this all the time, it's incredibly useful.
