Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
I found a way to create a vlookup through scripting in JSL, but is there a possibility to include something like this in the formula editor under the Comparison menu?
Hi Ana, Have you tried "Match"? If you select the column name first and single-click on "Match", it shows you a submenu where you can automatically add the Match arguments from the data (i.e. the values in your column). Then you can add the value you want returned in each then clause.
