  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
Column properties - allow multiple spec limits and control limits based on phase
Would be nice to have more flexible column properties for spec limits and control limits. Current column properties allow only one spec limit or control limit. But many SPC users will have changing control limits and spec limits over time. Currently Control Chart Builder can use a Phase column to separate calculated control limits. Saving to a table it will show the _LCL, _Mean, _UCL, etc. for each phase, with phase as an additional column. Could spec limits and control limits work in this manner? The ability to use a table to pull in the requirements, or save from Control Chart Builder to the Column and not just the table? See wish list requests for more flexible Value Ordering and Value Labels column properties that may interact with JMP tables. Not sure how it would work with all platforms, such as Process Screening. Currently have to write scripts to add changing control limits or spec limits to charts and other platforms.
6 Comments
Ryan_Gilmore
Community Manager
Status changed to: Archived
Peter_Hersh
I just heard this request again today.  Could we please revisit this request and not have it be archived.  This has also been more recently asked for with Expand Spec Limits Capability - JMP User Community and Expand SPEC Limits Options - JMP User Community
jthi
Any updates on getting this non-archived?
Thank you for your message! Your wish has been unarchived and will be reviewed.
I have met with 2 large semiconductor customers in the past 2 weeks that requested the ability to overlay multiple spec limits by phase or some other by variable.
jthi
@Clark_Ledbetter if it is only for graphing purposes, currently I would say it is easiest to do with Graph Builder if they have stacked data and specification limits in their own columns (this is what I have done for some of our reporting and tools). It does take some effort as you have to have multiple graph types on top of each other but if they generally use specific types of graphs, they could write a script or create add-in for it.
This is just one example what it can look like, grouping can be done in many different ways depending on the final needs
