Column Switcher + Transform Columns
☐ cool new feature
☐ could help a lot of Jmp users!
☑ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
The Column Switcher is very useful - but it has one major drawback:
The user can only specify which column to replace - but not WHERE in the graph.
If a column appears in multiple places in the graph, ALL of them are replaced with the new column selected in the Column Switcher. So Column Switcher feels a bit like "Column Switcher light".
A great add-in that solves the problem:
 Column Quick Swapper - easily change multiple Y and X-axis columns in Graph Builder
What remains is the opposite issue:
A column is only replaced by Column Switcher, if it appears directly in GraphBuilder.
If a column is used in a Transform Column, Column Switcher ignores it.
Please add an  option to Column Switcher to replace columns in Transform columns as well.
Why is this idea important?
Column Switcher is cool  - Transform columns are essential for certain use cases.
Column Switcher + Transform Columns is a nightmare.
With the new functionality, Column Switcher + Transform Columns will become a dream team :)
1 Comment
hogi
Level XIII
application case:
- Transform column - Cumulative Probability for height
- height gets replaced by weight - via column switcher
- unfortunately, the transform column still refers to height.
