Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
I would like to be able to add a factor to a previously ran Custom DOE. So an extension of the augment DOE platform that allows me to add a new factor where I could tell you what that factors was set to for the runs that are already done.
It seems this Wish List item is still needed, so that users don't rely on workarounds and "tricks" to augment their DoE in the correct way : Add new levels to a design
I do think making it easier to add additional colums/factors to an exisiting design would be beneficial. It is a task I frequently have to do when working with a team to design studies. Being able to do both adding factors with optimal factor levels and/or adding rows to the design to reduce confounding and increase power would be a great new feature.
6 Years and counting...i'm starting to loose faith in this wish list forum. I think this request is way simpler than some of the things we have seen added to JMP since I posted this.
