  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Augment DOE with new factor
I would like to be able to add a factor to a previously ran Custom DOE. So an extension of the augment DOE platform that allows me to add a new factor where I could tell you what that factors was set to for the runs that are already done.
14 Comments
cwillden
Super User (Alumni)
Interesting idea, but I can imagine things would get really interesting if the whole prior experiment is 1 random block, and then you want to fully randomize that factor in the new runs.
louv
Staff (Retired)
I was able to accomplish this by adding a new column and entering the setting for the factor of interest. Then when I augment I include that factor in setup and edit the range in the dialog box. The resulting augment with block has the additional runs at the new setting and codes the column info accordingly.
pauldeen
Level VI
Yes this can be manually hacked but it would be nice if it was driven by the augment platform and also gave me a recommendation as to how many extra runs I need to accomplish proper characterization.
louv
Staff (Retired)
I would hardly call this "manually hacked" No software can read your mind if you have a factor that you knew the setting of during the initial experiment in question that you later decide to add and include in a subsequent study. Once the new factor is captured the rest is totally driven by the augment platform.
MathStatChem
Level VII
If you want to repeat the original design but add a new factor in, you can do this currently by creating a new design, adding the new factor, and they using the original DOE table add the factors as covariates.
If you observed the factor (it was an uncontrolled covariate) in the original design, you can add the covariate column and it's values into the DOE table, and then augment using all original DOE factors and the covariate.
Ryan_Gilmore
Community Manager
Status changed to: Archived
pauldeen
Level VI
I would still like a dialog option as part of the augment platform that allows me to add new factors. Once I click a new factor in, it will ask me what it was set to in the original runs and then it helps me build the right structure in the new runs.
hogi
Level XIII
@Ryan_Gilmore , could you please re-open the wish.
Augmenting an DOE is one of the "miracles", an experienced user can do for sure in JMP. Just a few steps and you are done - if you know the steps.
When you look at all the other functionalities in JMP - almost always there is a GUI which guides the user through the process.
Why is this not possible for adding a new column to augment a DOE?
... you could even implement it in easy DOE - and ask @Ryan_Lekivetz 's daughter to try it.
pauldeen
Level VI
Thank you @hogi nicely stated. It is not that it cannot be done in the current form, but it could be a lot easier.
hogi
Level XIII
@Sarah-Sylvestre , is it possible to re-open the Wish.
shall we write a new wish?
