%3CLINGO-SUB%20id%3D%22lingo-sub-704938%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ESeguimiento%20de%20auditor%C3%ADa%20para%20la%20entrada%20de%20datos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-704938%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%C2%BFQu%C3%A9%20inspir%C3%B3%20esta%20solicitud%20de%20lista%20de%20deseos%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EA%20veces%2C%20los%20archivos%20JMP%20se%20comparten%20para%20colaborar%20y%20varias%20personas%20editan%20la%20tabla%20JMP.%20Cualquiera%20puede%20realizar%20cambios%20y%20no%20es%20inmediatamente%20obvio%20c%C3%B3mo%20ha%20cambiado%20el%20archivo%20cuando%20se%20comparte.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%C2%BFCu%C3%A1l%20es%20la%20mejora%20que%20le%20gustar%C3%ADa%20ver%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3ESer%C3%ADa%20bueno%20si%20hubiera%20una%20pista%20de%20auditor%C3%ADa%20para%20poder%20ver%20qui%C3%A9n%20hizo%20qu%C3%A9%20cambio%20y%20cu%C3%A1l%20fue%20el%20cambio.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%C2%BFPor%20qu%C3%A9%20es%20importante%20esta%20idea%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EM%C3%A1s%20visibilidad%20de%20lo%20que%20ha%20pasado%20con%20los%20archivos%20JMP%20que%20se%20comparten.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-704938%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EOrganizaci%C3%B3n%20de%20contenidos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-767008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Registro%20de%20auditor%C3%ADa%20para%20entrada%20de%20datos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-767008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EEstoy%20de%20acuerdo%2C%20esto%20es%20definitivamente%20algo%20%C3%BAtil%20para%20los%20ensayos%20cl%C3%ADnicos.%20Ten%C3%ADa%20muchas%20solicitudes%20para%20JMP%20Clinical.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-871080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Registro%20de%20auditor%C3%ADa%20para%20la%20entrada%20de%20datos%3A%20estado%20cambiado%20a%3A%20Reconocido%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-871080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGracias%20por%20enviar%20esta%20solicitud.%20Ya%20la%20hemos%20revisado%20y%20la%20actualizaremos%20si%20cambia%20de%20estado.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Audit Trail for Data Entry
Sometimes JMP files are shared for collaboration where multiple people edit the JMP table. Anyone can make changes and it's not immediately obvious how the file has changed when it's shared.
It would be nice if there was an audit trail so you can see who made what change and what the change was.
Why is this idea important?
More visibility to what has happened with JMP files that are shared.
2 Comments
I agree, this is definitely something that is useful for clinical trials. I had many requests for JMP Clinical.
Thank you for submitting this request! This has been reviewed and we will update this wish if the status changes.
