  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
Ashby Plot
Why is this idea important?
3 Comments
jwiltsie
Level III
It didn't post my answers in the original, so here they are:
What inspired this wish list request? Materials engineers commonly use Ashby plots to compare material properties of various materials.
Implement an Ashby Plot option in JMP Graph Builder. It would be good to have the option for nested catoegories as shown in the graph below.
In JMP 17, Graph Builder using 'Contours' with the 'HDR' contour type gets close to what I would like but it does not have options to include all data points inside the shape and the shape extends beyond the points. Also, it has multiple contour levels which cannot be turned to one level.
Why is this idea important? It would help communicate how our products' properties compare to currently existing products.
SamGardner
Level VII
@jwiltsie can you describe what the size and shape of the ovals in the example plot you pasted are?  Looking at some web references on this, the boundaries appear to generally be some sort of smoothed "convex hull" of the data points in each group.
jwiltsie
Level III
Yes, the shapes are a smoothed perimeter bounding all of the points in each group.
