Additional Graph Builder Preferences to Match Control Chart Builder
One feature I like in Control Chart Builder are that I can update my Preferences to turn on features I like. For instance, I like utilizing the Graph Spacing, Graph Spacing Color, Graph Spacing Transparency, and Graph Borders features. Only 1 of these is available in Graph Builder (Graph Spacing). You can manually do the other 3, but you can’t save this as a repeated feature.
My recommendation is to add the CCB Preferences of Graph Spacing Color, Graph Spacing Transparency, and Graph Borders to the Graph Builder Preferences.
Why is this idea important?
It's good to have consistency between similar platforms. Here is an example of using the Cereal data set. I set Graph Spacing from 1 to 15 using the red triangle in Graph Builder. Then when I right-click on the spacing, I can change the Transparency to 0 and add Graph Borders.
1 Comment
Sarah-Sylvestre
Level V
Thank you for submitting this request!
