  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Additional Graph Builder Preferences to Match Control Chart Builder
One feature I like in Control Chart Builder are that I can update my Preferences to turn on features I like. For instance, I like utilizing the Graph Spacing, Graph Spacing Color, Graph Spacing Transparency, and Graph Borders features. Only 1 of these is available in Graph Builder (Graph Spacing). You can manually do the other 3, but you can’t save this as a repeated feature.
My recommendation is to add the CCB Preferences of Graph Spacing Color, Graph Spacing Transparency, and Graph Borders to the Graph Builder Preferences.
Why is this idea important?
It's good to have consistency between similar platforms. Here is an example of using the Cereal data set. I set Graph Spacing from 1 to 15 using the red triangle in Graph Builder. Then when I right-click on the spacing, I can change the Transparency to 0 and add Graph Borders.
1 Comment
Sarah-Sylvestre
Level V
Thank you for submitting this request!
