Adding multiple Y-axis
Hi JMP,
I'm looking for a fully functional version of what is described in this post ( Multiple Y-Axis Graphs ) i.e. being able to add multiple types of data scaled to different Y-axis on the same graph. As in the comments, this type of graph would critical for process or engineering visualization where multiple parameters in time series need to be viewed simultaneously. This type of visualization has been eluding me for years.
Happy to discuss more and looking forward to seeing this in the future
5 Comments
jthi
You can kind of do this with your method of choice: scaling by range, standardization, normalization... (you will of course lose the information on the original values, but in graphs shape might be).
With Range 0 to 1 formula:
With the script from topic:
Without any transformations:
SamGardner
Level VII
@RobBinkleyDebut thank you for your sugesstion.  We will take this under consideration.
mia_stephens
@RobBinkleyDebut Hello! We are currently looking into this request and I am hoping for a bit more information. Would the solution @jthi posted be sufficient for you or do you need to see the original values on the Y-Axis?  If so, why?
Status changed to: Needs Info
