Instantly extract effect sizes, F-ratios, and FDR-adjusted p-values from your models with the Calculate Effects Sizes extension, available now in the JMP Marketplace!
New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
Your voice matters! Tell us how you prefer to receive JMP updates, so we can tailor our communication to your needs. Take short survey.
Hi @andrewtkarl , thank you for this request. Can you please provide some additional information on what you'd like to see and/or an example? For example: Units always on? Global preference? Flag for each Tabulate session? Flag for each column in Tabulate? Something that applies to tables outside of Tabulate?
Thanks, @mia_stephens . I was only thinking about within tabulate, just showing the units in parentheses after the column name (in the same way that Graph Builder will use them to label an axis). My guess is that it would make sense to default to this behavior and then have a Tabulate option to turn off the units.
