Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Hi @andrewtkarl , thank you for this request. Can you please provide some additional information on what you'd like to see and/or an example? For example: Units always on? Global preference? Flag for each Tabulate session? Flag for each column in Tabulate? Something that applies to tables outside of Tabulate?
Thanks, @mia_stephens . I was only thinking about within tabulate, just showing the units in parentheses after the column name (in the same way that Graph Builder will use them to label an axis). My guess is that it would make sense to default to this behavior and then have a Tabulate option to turn off the units.
