  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
Add new quick formula which can be used to compare if selected column values are same in the row
From time to time I come across situation where I would like to quickly check if two columns have exactly same results in rows. I usually do this by writing new column with :COL1 == COL2 for example. It would be nice to have this as an New Formula option in right click menu (and hopefully support more than 2 columns).
3 Comments
Hi @jthi, thank you for taking the time to submit this idea! We will review your request and keep you updated on its status.
hogi
Level XIII
I often have the same issue - and miss this functionality.
But seems that the both of us are the only ones who "regularly" compare values in different columns - and have the wish to facilitate the step.
As other wishes to improve the new formula column menu got rejected (developers want to keep the menu "slim") , I fear that this one won't find it's way into JMP either.
Nevertheless, with the new New Formula column/Formula ... entry it got significantly easier to create such a formula column manually:
use the new entry
... add = and the second column. done.
Hm ....
hogi
Level XIII
Ah, I even submitted a wish:
new formula column: equals
unfortunately: 0 Kudos up to now.
