%3CLINGO-SUB%20id%3D%22lingo-sub-595976%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAggiungi%20una%20nuova%20formula%20rapida%20che%20pu%C3%B2%20essere%20utilizzata%20per%20confrontare%20se%20i%20valori%20della%20colonna%20selezionata%20sono%20gli%20stessi%20nella%20riga%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-595976%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EDi%20tanto%20in%20tanto%20mi%20imbatto%20in%20situazioni%20in%20cui%20vorrei%20verificare%20rapidamente%20se%20due%20colonne%20hanno%20esattamente%20gli%20stessi%20risultati%20nelle%20righe.%20Di%20solito%20lo%20faccio%20scrivendo%20una%20nuova%20colonna%20con%20%3ACOL1%20%3D%3D%20COL2%20per%20esempio.%20Sarebbe%20bello%20averlo%20come%20opzione%20Nuova%20formula%20nel%20menu%20di%20scelta%20rapida%20(e%20si%20spera%20che%20supporti%20pi%C3%B9%20di%202%20colonne).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-595976%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3ECombinazione%20e%20pulizia%20dei%20dati%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EEsplorazione%20e%20visualizzazione%20dei%20dati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-598803%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Aggiungi%20una%20nuova%20formula%20rapida%20che%20pu%C3%B2%20essere%20utilizzata%20per%20confrontare%20se%20i%20valori%20della%20colonna%20selezionata%20sono%20uguali%20nella%20riga%20-%20Stato%20modificato%20in%3A%20Riconosciuto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-598803%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ECIAO%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F14366%22%20target%3D%22_blank%22%3E%20%40jthi%3C%2FA%3E%20%2C%20grazie%20per%20aver%20dedicato%20del%20tempo%20per%20inviare%20questa%20idea!%20Esamineremo%20la%20tua%20richiesta%20e%20ti%20terremo%20aggiornato%20sul%20suo%20stato.%3CSPAN%20class%3D%22Apple-converted-space%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-778617%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ERi%3A%20Aggiungi%20una%20nuova%20formula%20rapida%20che%20pu%C3%B2%20essere%20utilizzata%20per%20confrontare%20se%20i%20valori%20della%20colonna%20selezionata%20sono%20gli%20stessi%20nella%20riga%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-778617%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3ESpesso%20ho%20lo%20stesso%20problema%20e%20mi%20manca%20questa%20funzionalit%C3%A0.%3C%2FP%3E%3CP%3EMa%20sembra%20che%20entrambi%20siamo%20gli%20unici%20a%20confrontare%20%22regolarmente%22%20i%20valori%20in%20diverse%20colonne%20-%20e%20desideriamo%20facilitare%20il%20passaggio.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EPoich%C3%A9%20altri%20desideri%20di%20migliorare%20il%20nuovo%20menu%20della%20colonna%20formula%20sono%20stati%20respinti%20(gli%20sviluppatori%20vogliono%20mantenere%20il%20menu%20%22snello%22)%2C%20temo%20che%20neanche%20questo%20trover%C3%A0%20la%20sua%20strada%20in%20JMP.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3ETuttavia%2C%20con%20la%20nuova%20voce%20%3CSTRONG%3ENuova%20colonna%20formula%2FFormula...%3C%2FSTRONG%3E%20%C3%A8%20diventato%20molto%20pi%C3%B9%20semplice%20creare%20manualmente%20una%20colonna%20formula%20di%20questo%20tipo%3A%3C%2FP%3E%3CP%3Eutilizzare%20la%20nuova%20voce%3C%2FP%3E%3CP%3E...%20aggiungi%20%3D%20e%20la%20seconda%20colonna.%20Fatto.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EMhm....%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22hogi_0-1722635827650.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22hogi_0-1722635827650.png%22%20style%3D%22width%3A%20358px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22hogi_0-1722635827650.png%22%20style%3D%22width%3A%20358px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22hogi_0-1722635827650.png%22%20style%3D%22width%3A%20358px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66788iECACAA653681EF10%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22hogi_0-1722635827650.png%22%20alt%3D%22hogi_0-1722635827650.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-778626%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ERi%3A%20Aggiungi%20una%20nuova%20formula%20rapida%20che%20pu%C3%B2%20essere%20utilizzata%20per%20confrontare%20se%20i%20valori%20della%20colonna%20selezionata%20sono%20gli%20stessi%20nella%20riga%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-778626%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EAh%2C%20ho%20anche%20espresso%20un%20desiderio%3A%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2Fnew-formula-column-equals%2Fm-p%2F657291%23U657291%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-idea-thread%20lia-fa-icon%20lia-fa-idea%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3Enuova%20colonna%20formula%3A%20uguale%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20purtroppo%3A%200%20Complimenti%20fino%20ad%20ora.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Add new quick formula which can be used to compare if selected column values are same in the row
From time to time I come across situation where I would like to quickly check if two columns have exactly same results in rows. I usually do this by writing new column with :COL1 == COL2 for example. It would be nice to have this as an New Formula option in right click menu (and hopefully support more than 2 columns).
3 Comments
Hi @jthi, thank you for taking the time to submit this idea! We will review your request and keep you updated on its status.
hogi
Level XII
I often have the same issue - and miss this functionality.
But seems that the both of us are the only ones who "regularly" compare values in different columns - and have the wish to facilitate the step.
As other wishes to improve the new formula column menu got rejected (developers want to keep the menu "slim") , I fear that this one won't find it's way into JMP either.
Nevertheless, with the new New Formula column/Formula ... entry it got significantly easier to create such a formula column manually:
use the new entry
... add = and the second column. done.
Hm ....
hogi
Level XII
Ah, I even submitted a wish:
new formula column: equals
unfortunately: 0 Kudos up to now.
