Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
Not sure why it didn't post my answers to the questions.
The idea to is add the typical maximize/minimize window buttons to the upper right of the PDF Import Wizard screen. I've been using the wizard a lot lately, and it can be tedious to manually move and resize the window to get it to full screen (which is helpful to clearly see text in the PDF image).
