Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Not sure why it didn't post my answers to the questions.
The idea to is add the typical maximize/minimize window buttons to the upper right of the PDF Import Wizard screen. I've been using the wizard a lot lately, and it can be tedious to manually move and resize the window to get it to full screen (which is helpful to clearly see text in the PDF image).
