Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
Not sure why it didn't post my answers to the questions.
The idea to is add the typical maximize/minimize window buttons to the upper right of the PDF Import Wizard screen. I've been using the wizard a lot lately, and it can be tedious to manually move and resize the window to get it to full screen (which is helpful to clearly see text in the PDF image).
