Add flag to Words() function to allow delimiters to be treated as one instead of many
Currently JMP's Words() function will split by any characters found from delimiters. Add a flag parameter which would allow user to use the delimiter string as one instead of any
Names Default To Here(1);
str1 = "a.,b.,c,d"; // last value should be c,d
//Show(Items(str1, ".,"));
Show(Words(str1, ".,"));
Most likely same feature could be added to Word(), Item() and Items() as they perform similar operations.
4 Comments
Jeff_Perkinson
Community Manager
Admittedly, a flag (or new function) as suggested would be nice but it's not too bad to deal with now by using Substitute() to convert the delimiter string into a single character.
str1 = "a.,b.,c,d.,e,f";
words(substitute(str1, ".,", "-"), "-");
//{"a", "b", "c,d", "e,f"}
 You do have to choose a character that doesn't appear anywhere in the string.
hogi
Level XIII
In general, I would prefer to implement such standard options in the function - even if there is kind of a workaround.
The benefit of the "option": EVERY user can use the option, but just a few users will find the workaround (on their own or by community search)
Nevertheless: nice workaround -> ideal candidate for Scripting Index 2.0 :)
JMP Scripting Index feedback and discussion
This option (define the whole sequence of characters as a single separator) would be a great improvement for Col/Utilities/Text to columns :)
Here @Jeff_Perkinson 's trick can be applied as well - but nobody would substitute in JSL and then use Text to columns to split the phrase.
And there are for sure some Jmp users who will be happy to have a non-JSL solution.
How about implementing it there as well?
Jeff_Perkinson
Community Manager
There's an implication that my workaround could only work in JSL here. Indeed, you could easily do the Substitute() in the Formula Editor for a new column and then use Text to columns on the new column.
hogi
Level XIII
good point.
What I mean is:
Users would love to get everything done just via Text to columns command from the menu -  without having to do anything in addition.
Such a checkbox could also improve the functionality to (MFI) txt import:
Here it's vice versa: MFI interprets several separator characters as several separators - but sometimes the user wants to import a table where (1 - N) spaces are used as a single separator.
--> a checkbox could help :)
ah, Spaces
