Contour Plots - Color Scheme and Reverse Colors Options
Hello,
In JMP 16, the options for the color scheme and reverse colors for Contour Plots were moved from the hot-key menu to a different menu that is accessed by right-clicking (in Windows) on the color legend. This is problematic because selections of / changes to these options can no longer be broadcast across multiple contour plots and each one needs to be handled individually. Can these options be moved back to the hot-key menu? If not, can functionality be added to the current menu to enable the use of broadcast mode?
This was also reported to Tech Support in June 2021.
