  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Add example to Items() documentation in scripting index to show how to break a string into lines
What inspired this wish list request? Please describe the current issue that needs improvement or the problem to be solved that is not easy or possible right now, with an example use case.
Users may need to break strings into lines.
What is the improvement you would like to see? Please describe the idea for improving JMP. Please include mock-ups, wireframes, screenshots, scripts, other documents or examples from other software that help describe the change you would like to see.
Documented example of breaking string into lines.
textLines = Items(text, Hex To Char("0D", "us-ascii"));
Why is this idea important? Please describe the value to you and/or other users if the idea is implemented (for example, ease of use, must have,…).
This will save users time.
2 Comments
hogi
Level XIII
What is the benefit compared to
items(text, "\!n")
