Hover over script in window list should also show file path
When sharing link to script to others, if I have script open, I then need to guess and check where the script was saved to.
I would like to see similar functionality for hovering over scripts in JMP Home Window's "Recent Files" section in the "Window List" section, specifically adding the filePath.
Why is this idea important?
This will help prevent confusion if working on similar named scripts from different folders.
1 Comment
Sarah-Sylvestre
Level V
Thank you for submitting this request!
