  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Add ability to add current, open data tables to current Project file without requiring save and re-import
What inspired this wish list request? While attending a training put on by the JMP User Support team (Clark Ledbetter), I noticed that JMP Projects seem a good way to keep various analyses organized and separate.  However, if the analysis is still evolving (i.e., taking in new data), it requires a data table to be saved before being dragged-and-dropped from Windows Explorer into the project.  Updating data tables currently-housed in the Project (e.g., using the Update Table function) is impossible without so many workarounds that render it impractical.
What is the improvement you would like to see?  I would like to be able to designate tables (via the Home Window or other means) to be included in a Project.  I would also like the Project data tables to be able to interact normally with other data tables currently open in JMP (the assumption being that the new merge/updated table should be able to be easily made a part of the Project as well).
Why is this idea important?  JMP Projects' use are currently limited to after-the-fact organization of data and graphs for documentation and presentation.  The ability to interact more seamlessly with currently-open (but not yet saved) data tables would allow the use of Projects for currently ongoing analyses as well.  I often find myself multitasking with many similarly-named data tables open at one time; the ability to stick them into different projects as I am working on them would be a big boost to my ongoing work organization. I am sure I am not alone in this regard.
I am using JMP18.1.1.
2 Comments
hogi
Level XIII
There exist multiple ways to move (unsaved) data tables into projects:
- newly generated data tables are automatically generated within the project.
- tables can be moved into a project via
Besides USING a data table inside a project, you can also STORE the data table right in the project - just grab it in the Workspace area and drag it into the Content area:
Another way to store the data table in the Project: click on the standard Save icon - but from within a project,
Then you will see a special menu where you can select the option to store the data table inside the project:
Sarah-Sylvestre
Level V
Thank you for sharing this request As @hogi mentioned in the comments, there is some existing functionality that I believe fulfills at least part of your request. Let me know if those features are helpful.
