  • See how to use JMP Pro to analyze and predict using entire data set rather than selected points in a curve. Register for Nov. 6 Mastering JMP.
Add a "max threads" argument for new multi http request()
to limit the number of simultaneous HTTP calls.
Something like this
custom_multi_http = Function( {mm, max = 30},
//mm=multi_http_requests;
	//max=5;
	res = {};
	status = {};
	mm_get = mm << get requests;
	chunks = Ceiling( N Items( mm_get ) / max );
	chunk_list = {};
	For( i = 1, i <= chunks, i++,
		chunk_i = New Multi HTTP Request();
		For( j = 1 + (i - 1) * max, j <= Min( max * i, N Items( mm_get ) ), j++,
			chunk_i << Add( mm_get[j] )
		Wait( 0 );
		chunk_i_requests = chunk_i << get requests;
		Insert Into( res, chunk_i << Send() );
		Insert Into( status, chunk_i_requests << get status() );
	Return( res, status );
7 Comments
Sarah-Sylvestre
Level V
Hi @andrewtkarl, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
mia_stephens
@andrewtkarl , the developer shared this:
Currently a user can write a script using HTTP Request with Send(asnyc) that will return a JSL promise. They can track the number of promises, which will be the concurrent connections.
When a promise has finished (with onResult or onError) they can queue up more requests.
Here’s an example of handling the maximum concurrent HTTP Requests using HTTP Request and JSL Promises shared by @bryan_boone :
Names Default To Here( 1 );
//populate the requests
requests = {};
promises = {};
count = 100;
max = 30;
For(i = 1, i <= count, i++,
	request = New HTTP Request( //this is the HTTP Request for the Query String Example in the SI
		url( "http://httpbin.org/get" ),
		Method( "GET" ),
		Query String( [["username" => "bob", "address" => "12345", "count"=>i]] )
	InsertInto(requests, request);
//now send them async
process_result = Function( {p, r},
	//Show(p);
	//Show( r );
	if(N Items(promises),
		RemoveFrom(promises, 1);
process_error = Function( {p, e, t},
	//Show(p);
	//Show( e );
	//Show( t );
while(N Items(requests),
	count = max - N Items(promises);
	if(count > N Items(requests),
		count = N Items(requests);
	Show(count);
		request = requests[1];
		RemoveFrom(requests, 1);
		promise = request << Send( "async" );
		InsertInto(promises, promise);
		promise << On Result( process_result );
		promise << On Error( process_error );
	If(Nitems(promises),
		wait(0);
//catch any stragglers
while(Nitems(promises),
	wait(0);
Write("\!nDone!!!\!n");
mia_stephens
@andrewtkarl , does @bryan_boone's response satisfy this request?
andrewtkarl
Level IV
@mia_stephens Yes it does, thank you both for your help.
mia_stephens
Thanks for the confirmation @andrewtkarl. Will mark this as delivered.
mia_stephens
Status changed to: Delivered
