Add Value Labels option in Column Recode
The column recode platform is a lot easier to use than the value label option.  It would be awesome to use the column recode platform and have an option to save as value labels in addition to the current options of a new column or formula or overwrite the existing column.
5 Comments
Vball247
Level V
Is your request from JMP13? In JMP14, the Column Recode platform now has an option under the inverted red triangle to "Add Value Labels". But still have to manually type in. Would be nice to have the option to save as a file and import as a file, if used often, instead of having type in each time. Will add this request as a separate wish list. Similar request for Value Ordering.
Jeff_Perkinson
Community Manager
As noted above, JMP 14 has an option to set Value Labels. Change the Recode to In Place and choose Add Value Labels from the red triangle menu.
Jeff_Perkinson
Community Manager
Status changed to: Already Offered
Ryan_Gilmore
Community Manager
Status changed to: Delivered
hogi
Level XIII
Thanks, very useful :)
