  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Add Parse Date as a New Formula Column option
It is sometimes safer to parse dates using a new column instead of changing the value in-place using an input format.  See discussion at Tricks to prevent incorrect input date formats from resulting in missing values?. Adding an option in the new formula column to parse that date using a format specified by the user would make this easier.
1 Comment
jthi
The platform is also almost there with the JMP16's Custom Date-Time Formatting with Format Patterns Youtube: Custom Date Formatting in JMP 16 . Not sure if you can do it directly with right-click New Formula column (don't have JMP16 on this PC to verify).
