  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Access regulation individual tables
I need to control the access level of each individual tables, so most people can open and copy the table but cannot change anything in the table. But "read-access" status should not prevent the automatic update from the database, or scripts that uses those tables. I just want to secure the structure in the tables.
2 Comments
Sarah-Sylvestre
Level V
Hi @Metin_Tueluemen, thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
Status changed to: Not Planned For Now
@Metin_Tueluemen we have reviewed this request.  We do not plan to provide user level access control features in JMP.  These are typically provided at and operating system and file system level.
There is a feature to allow you to lock a data table, see this page, which prevents changing data or column properties.
