Access regulation individual tables
I need to control the access level of each individual tables, so most people can open and copy the table but cannot change anything in the table. But "read-access" status should not prevent the automatic update from the database, or scripts that uses those tables. I just want to secure the structure in the tables.
2 Comments
Hi @Metin_Tueluemen, thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
Status changed to: Not Planned For Now
@Metin_Tueluemen we have reviewed this request.  We do not plan to provide user level access control features in JMP.  These are typically provided at and operating system and file system level.
There is a feature to allow you to lock a data table, see this page, which prevents changing data or column properties.
