  • See how to use the JMP Marketplace – Free tools to expand JMP capabilities. Register. July 10, 2 pm US Eastern Time.
3D Graph Builder
Scatter Plot has limited functionality for 3D graphing. Graph Builder is only two-dimensional graphing which limits some potential use applications.
Graph builder but in with a 3rd dimension (Z) as an option. Similar functionality to graph builder like drag-n-drop, overlay, coloring, grouping on axis (X, Y, Z) with functionality from scatter plots like Mesh, points, surfaces.
Why is this idea important?
When looking at a 2D surface with measured values in the 3rd axis is useful and can be done with scatter plot, though this does not have a lot of the functionality built into graph builder. Ideally want to color a surface plot by a 4th metric, such as change in the 3rd axis value or a 4th metric. Allows for graphical representation of two factors over a 2d surface in single graph.
Could also show the difference between two 3D surface plots with one being the reference and the coloring being the difference between the two surface plots.
1 Comment
SarahGilyard
Thank you for posting. Are you using a prediction formula to interpolate across the surface or just measured values? If you have a prediction formula you could use the surface plot option under the graph menu. In general, we are exploring improving our 3D graphing functionality and we'd like to hear more about your use case. Thanks!
