  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Ability to specify minimum power requirements for expirement effects and have treatments and replicates/run number determined using custom design.
Currently if you are required to hit minimum power requirements for specific expierement effects you need to generate the design, check the power analysis, evaluate if you met the requirements.... if not you need to return to the design and make changes (add replicates, ect). It would be ideal if we can specify RMSE, alpha, and power in the factor definition table.
It would be ideal if we can specify RMSE, alpha, and power in the factor definition table and when the design is generated it takes this into consideration and provides designs which meet the expirement confidence requirements.
Why is this idea important?
It is important because the current optimization method is focused on minimizing cost while maximizing learnings. Allowing the user to determine what "costs" should be optimized would be signifigantly more useful and speed up expierement design.
1 Comment
mia_stephens
Thank you for this suggestion @alahse! We've added this to a prior request.
