  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
3D Graph Builder
Scatter Plot has limited functionality for 3D graphing. Graph Builder is only two-dimensional graphing which limits some potential use applications.
Graph builder but in with a 3rd dimension (Z) as an option. Similar functionality to graph builder like drag-n-drop, overlay, coloring, grouping on axis (X, Y, Z) with functionality from scatter plots like Mesh, points, surfaces.
Why is this idea important?
When looking at a 2D surface with measured values in the 3rd axis is useful and can be done with scatter plot, though this does not have a lot of the functionality built into graph builder. Ideally want to color a surface plot by a 4th metric, such as change in the 3rd axis value or a 4th metric. Allows for graphical representation of two factors over a 2d surface in single graph.
Could also show the difference between two 3D surface plots with one being the reference and the coloring being the difference between the two surface plots.
1 Comment
SarahGilyard
Thank you for posting. Are you using a prediction formula to interpolate across the surface or just measured values? If you have a prediction formula you could use the surface plot option under the graph menu. In general, we are exploring improving our 3D graphing functionality and we'd like to hear more about your use case. Thanks!
