  • JMP multivariate capabilities let you understand relationships between multiple variables simultaneously. See how. Friday, Aug. 14, 2 pm US ET.
JMP On Air
Annotating Control Charts
(view in My Videos)
Do you need to annotate control charts with known events? In this segment, JMP Systems Engineer Byron Wingerd shows you how to “make your control charts rock.” Follow along as Byron uses JMP to demonstrate how to create scripts that can be added to control chart graphs that facilitate drawing event lines and adding comments to graphs. Along the way, Byron will also show you multiple ways to annotate points in your control chart to make sure you’re properly highlighting things in your data that you want to stand out.
Comments
Byron_JMP
During this segment I mentioned a couple of pages in the JMP community. These are the links to those pages.
Control Charts with a Relative X-Axis Scale
Event Lines and Comments on Control Charts
