  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
JMP Library
Getting Started with JMP
New to JMP? Start here. Through short videos and guided practices, you’ll learn to navigate data tables, explore data with interactive graphs, clean up common data issues, and save your work as reusable scripts.
Select Start Course to begin building the skills you need to make discoveries with your own data!
If you are looking for the older/longer version of this course, you can find it here.
Comments
Amazing format: Short videos, great explanations, question to ensure that the content can be applied. Thank you very much for sharing. Could this format be useful for you?
 @Aziza @Steffen_Bugge @JohannD @shoffmeister @Ole_Luehn @Andreas_Büchse @Will_Penland @gerd @Peter_Vogel @Georg
Aziza
Excellent! Thanks for sharing!
MaanasaT
Love this format of Getting Started, especially the practice problems! Thank you for this!
jpol
Hi,
I am unable to download the Excel file "Product and Supplier Info.xlsx"  from the Resources menu.
When I attempt to do so I get the "Not Found" error message.
Is the link broken or is there some other issue?
Thanks,
Philip
jpol
jthi  provided another link where the Excel file is located:
Getting Started with JMP Journal and Data - JMP User Community
@jpol Thanks.
Wish I would have known about this sooner. @monique_lander were you aware of this resource?
Is there a cert at the end of the introductory module?
anis72
it is working now . thanks
@anis72 what is not working?  The files are downloadable on this page and also here: https://community.jmp.com/t5/Learning-Center/Getting-Started-with-JMP-Journal-and-Data/ta-p/512472
And the video is working  on Chrome and Edge.  If you send details I can try to help.
StellaDiva
Where are the Companies.jmp and TeamResults.xls files?
SrClean
I cannot see the training video or any "begin" button. I get this:
ryandewitt
@SrClean Thank you, and I believe this is resolved.  Thank you for taking the time to comment on this, and please let us know if we can help with anything else.
-rd
Where can I find companies.jmp ??
Hi @Probabilities   All the sample files, including companies.jmp are in your JMP Program Files, for Example  C:\Program Files\JMP\JMP\18\Samples\Data and you can access them directly from JMP:
Thank you @gail_massari :)
Ozzy
Hi
Where can I find the 'JMP Orders' file? It is not in Sample Data folder under Help. Thanks in advance.
@Ozzy The JMP Orders file is included in the attached .zip fie.  Look top right column on this page.
I enjoy it
