JMP Blog
%3CLINGO-SUB%20id%3D%22lingo-sub-498289%22%20slang%3D%22zh-TW%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3ECome%20utilizzare%20JMP%20per%20completare%20l'analisi%20multivariata%20a%20fattore%20singolo%20in%20una%20sola%20volta%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-498289%22%20slang%3D%22zh-TW%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3EDopo%20aver%20compreso%20come%20eseguire%20la%20pulizia%20dei%20dati%20in%20JMP%2C%20avviare%20l'analisi%20statistica%20di%20base.%20In%20questo%20articolo%20e%20nei%20seguenti%20articoli%2C%20introdurremo%20uno%20per%20uno%20il%20processo%20di%20analisi%20della%20regressione%20lineare.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPrima%20di%20eseguire%20l'analisi%20multivariata%20di%20regressione%20lineare%2C%20%C3%A8%20spesso%20necessario%20condurre%20prima%20l'analisi%20univariata.%20Tuttavia%2C%20l'analisi%20a%20fattore%20singolo%20della%20maggior%20parte%20delle%20operazioni%20software%20comunemente%20utilizzate%20%C3%A8%20al%20momento%20ingombrante%20e%20l'analisi%20a%20fattore%20singolo%20di%20pi%C3%B9%20variabili%20indipendenti%20deve%20essere%20sostituita%20continuamente%20per%20ripetere%20l'operazione.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ETuttavia%2C%20dentro%3CSTRONG%3E%20JMP%3C%2FSTRONG%3E%3CSTRONG%3E%20L'analisi%20fattoriale%20singola%20di%20tutte%20le%20variabili%20indipendenti%20pu%C3%B2%20essere%20realizzata%20contemporaneamente%20nel%20software.%3C%2FSTRONG%3E%20L'articolo%20di%20oggi%20%C3%A8%20quello%20di%20condividere%20come%20utilizzare%20JMP%3CSPAN%3E%20Completa%20un'analisi%20univariata%20multivariata%20una%20tantum.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId-1710391648%22%20id%3D%22toc-hId-1731428677%22%20id%3D%22toc-hId-1731428677%22%20id%3D%22toc-hId-1731428677%22%20id%3D%22toc-hId-1731428677%22%3E%3CFONT%20size%3D%224%22%3E%3CSTRONG%3EPerch%C3%A9%20la%20regressione%20lineare%3F%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH2%3E%0A%3CP%3ERispetto%20all'analisi%20univariata%20con%20una%20sola%20variabile%20di%20gruppo%20sopra%20descritta%2C%20l'analisi%20multivariata%20%C3%A8%20pi%C3%B9%20comune%20nella%20pratica%2C%20poich%C3%A9%20la%20maggior%20parte%20dei%20risultati%20%C3%A8%20influenzata%20da%20pi%C3%B9%20di%20un%20fattore.%20Ad%20esempio%2C%20confrontando%20l'efficacia%20di%20due%20diversi%20farmaci%20nel%20trattamento%20del%20diabete%2C%20anche%20se%20c'%C3%A8%20una%20differenza%20nell'efficacia%20tra%20i%20due%20gruppi%2C%20potrebbe%20non%20essere%20attribuita%20a%20fattori%20farmacologici%2C%20perch%C3%A9%20molti%20fattori%20come%20BMI%2C%20pressione%20sanguigna%2C%20dieta%2C%20ecc.%20influenzer%C3%A0%20anche%20l'effetto%20del%20trattamento%20farmacologico%20allo%20stesso%20tempo%2C%20se%20questi%20Se%20i%20fattori%20sono%20sbilanciati%20tra%20i%20due%20gruppi%2C%20influenzer%C3%A0%20l'effetto%20di%20valutazione%20del%20farmaco.%20Pertanto%2C%20nella%20pratica%20utilizziamo%20spesso%20l'analisi%20multivariata.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EDi%20solito%20diciamo%20che%20%22correggere%22%20l'influenza%20di%20fattori%20come%20l'et%C3%A0%20e%20il%20sesso%2C%20o%20che%20il%20fumo%20%C3%A8%20un%20%22fattore%20prognostico%20indipendente%22%20per%20il%20cancro%20del%20polmone%2C%20questi%20si%20riferiscono%20all'analisi%20multivariata.%3CSTRONG%3E%20La%20regressione%20lineare%20viene%20spesso%20utilizzata%20nell'analisi%20multivariata%20di%20risultati%20quantitativi%20e%20viene%20utilizzata%20principalmente%20per%20descrivere%20la%20relazione%20lineare%20tra%20una%20o%20pi%C3%B9%20variabili%20indipendenti%20e%20risultati%20quantitativi.%3C%2FSTRONG%3E%20Quando%20vogliamo%20esplorare%20i%20fattori%20di%20rischio%20per%20un%20risultato%20quantitativo%2C%20di%20solito%20consideriamo%20prima%20la%20regressione%20lineare%2C%20quindi%20consideriamo%20altri%20metodi%20alternativi%20se%20la%20regressione%20lineare%20non%20%C3%A8%20adatta.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId--841765313%22%20id%3D%22toc-hId--820728284%22%20id%3D%22toc-hId--820728284%22%20id%3D%22toc-hId--820728284%22%20id%3D%22toc-hId--820728284%22%3E%3CFONT%20size%3D%224%22%3E%3CSTRONG%3EAnalisi%20univariata%20della%20regressione%20lineare%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH2%3E%0A%3CP%3E%3CSTRONG%3ELa%20cosiddetta%20analisi%20a%20fattore%20singolo%2C%20ovvero%20ogni%20regressione%20viene%20inserita%3C%2FSTRONG%3E%3CSTRONG%3E%201%3C%2FSTRONG%3E%3CSTRONG%3E%20variabili%20indipendenti%20e%20osservare%20la%20relazione%20tra%20ciascuna%20variabile%20indipendente%20e%20la%20variabile%20dipendente.%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAl%20momento%2C%20quando%20molti%20software%20statistici%20eseguono%20analisi%20a%20fattore%20singolo%2C%20possono%20inserire%20solo%20una%20variabile%20indipendente%20e%20quindi%20produrre%20un%20risultato%3B%20se%20vuoi%20vedere%20l'effetto%20di%20un'altra%20variabile%20indipendente%2C%20devi%20tornare%20indietro%20e%20rifarlo.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EImmagina%20se%20ci%20sono%2020%20variabili%20indipendenti%2C%20devi%20fare%20lo%20stesso%20lavoro%2020%20volte%20avanti%20e%20indietro.%20Questo%20processo%20%C3%A8%20molto%20noioso%20e%20richiede%20tempo.%3CSTRONG%3E%20JMP%3C%2FSTRONG%3E%3CSTRONG%3E%20Il%20software%20fornisce%20uno%20strumento%20per%20realizzare%20l'analisi%20fattoriale%20singola%20di%20tutte%20le%20variabili%20indipendenti%20in%20una%20sola%20volta%3C%2FSTRONG%3E%20.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPrendi%20i%20dati%20nella%20Figura%201%20come%20esempio%20per%20esplorare%20i%20possibili%20fattori%20che%20influenzano%20il%20punteggio%20di%20salute%20fisica.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Michelle_Wu_0-1654164483788.png%22%20style%3D%22width%3A%20555px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_0-1654164483788.png%22%20style%3D%22width%3A%20555px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_0-1654164483788.png%22%20style%3D%22width%3A%20555px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_0-1654164483788.png%22%20style%3D%22width%3A%20555px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_0-1654164483788.png%22%20style%3D%22width%3A%20555px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42902i5FB1C6F46CA6A574%2Fimage-dimensions%2F555x386%3Fv%3Dv2%22%20width%3D%22555%22%20height%3D%22386%22%20role%3D%22button%22%20title%3D%22Michelle_Wu_0-1654164483788.png%22%20alt%3D%22Michelle_Wu_0-1654164483788.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EFigura%201%20Dati%20di%20esempio%20(visualizzazione%20parziale)%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIn%20JMP%2C%20fare%20clic%20sul%20menu%20%22Analizza%22%20%E2%86%92%20%22Adatta%20Y%20per%20X%22%20(Figura%202)%20e%2C%20nella%20finestra%20di%20dialogo%20a%20comparsa%2C%20importare%20il%20punteggio%20di%20salute%20fisica%20in%20%22Y%2C%20risposta%22%20e%20importare%20tutte%20le%20variabili%20indipendenti%20in%20%22X%20%2C%20fattore%22%20(immagine%203).%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Michelle_Wu_1-1654164483803.png%22%20style%3D%22width%3A%20551px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_1-1654164483803.png%22%20style%3D%22width%3A%20551px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_1-1654164483803.png%22%20style%3D%22width%3A%20551px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_1-1654164483803.png%22%20style%3D%22width%3A%20551px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_1-1654164483803.png%22%20style%3D%22width%3A%20551px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42901i70B6DEB8B4D319FD%2Fimage-dimensions%2F551x341%3Fv%3Dv2%22%20width%3D%22551%22%20height%3D%22341%22%20role%3D%22button%22%20title%3D%22Michelle_Wu_1-1654164483803.png%22%20alt%3D%22Michelle_Wu_1-1654164483803.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%202%20Diagramma%20schematico%20dell'operazione%20di%20%22raccordo%20Y%20con%20X%22%20Passaggio%201%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Michelle_Wu_2-1654164483808.png%22%20style%3D%22width%3A%20522px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_2-1654164483808.png%22%20style%3D%22width%3A%20522px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_2-1654164483808.png%22%20style%3D%22width%3A%20522px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_2-1654164483808.png%22%20style%3D%22width%3A%20522px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_2-1654164483808.png%22%20style%3D%22width%3A%20522px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42900i1909D87131D8D4AB%2Fimage-dimensions%2F522x386%3Fv%3Dv2%22%20width%3D%22522%22%20height%3D%22386%22%20role%3D%22button%22%20title%3D%22Michelle_Wu_2-1654164483808.png%22%20alt%3D%22Michelle_Wu_2-1654164483808.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%203%20La%20seconda%20fase%20del%20diagramma%20operativo%20di%20%22adattamento%20di%20Y%20con%20X%22%3C%2FP%3E%0A%3CP%3EI%20risultati%20di%20output%20predefiniti%20sono%20mostrati%20nella%20Figura%204%20(vengono%20mostrate%20solo%203%20variabili%20indipendenti%20e%20le%20altre%20sono%20omesse)%20e%20nella%20pagina%20viene%20presentato%20solo%20il%20grafico%20a%20dispersione%20di%20ogni%20variabile%20indipendente%20e%20variabile%20dipendente.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Michelle_Wu_3-1654164483814.png%22%20style%3D%22width%3A%20524px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_3-1654164483814.png%22%20style%3D%22width%3A%20524px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_3-1654164483814.png%22%20style%3D%22width%3A%20524px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_3-1654164483814.png%22%20style%3D%22width%3A%20524px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_3-1654164483814.png%22%20style%3D%22width%3A%20524px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42904i2699FE3AB9237BF0%2Fimage-dimensions%2F524x186%3Fv%3Dv2%22%20width%3D%22524%22%20height%3D%22186%22%20role%3D%22button%22%20title%3D%22Michelle_Wu_3-1654164483814.png%22%20alt%3D%22Michelle_Wu_3-1654164483814.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%204%20Output%20di%20%22Adatta%20Y%20per%20X%22%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ESe%20lo%20desidera%3CSTRONG%3E%20Visualizza%20i%20risultati%20del%20test%20dell'analisi%20univariata%20per%20ogni%20variabile%20indipendente%3C%2FSTRONG%3E%20%2C%20%C3%A8%20necessario%20eseguire%20alcune%20operazioni%20successive%20in%20JMP.%20Si%20noti%20che%20le%20fasi%20operative%20sono%20diverse%20per%20variabili%20continue%20e%20variabili%20categoriali.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-704531517%22%20id%3D%22toc-hId-725568546%22%20id%3D%22toc-hId-725568546%22%20id%3D%22toc-hId-725568546%22%20id%3D%22toc-hId-725568546%22%3E%3CFONT%20size%3D%224%22%3E%3CSTRONG%3Evariabile%20continua%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH3%3E%0A%3CP%3EPer%20le%20variabili%20continue%2C%20prendi%20l'et%C3%A0%20come%20esempio%2C%20fai%20clic%20sulla%20freccia%20rossa%20verso%20il%20basso%20sul%20lato%20sinistro%20di%20%22Binary%20Fitting%22%20nell'interfaccia%20dei%20risultati%20%E2%86%92%20seleziona%20%22Fitting%20Line%22%20(Figura%205).%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Michelle_Wu_4-1654164483817.png%22%20style%3D%22width%3A%20490px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_4-1654164483817.png%22%20style%3D%22width%3A%20490px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_4-1654164483817.png%22%20style%3D%22width%3A%20490px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_4-1654164483817.png%22%20style%3D%22width%3A%20490px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_4-1654164483817.png%22%20style%3D%22width%3A%20490px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42903i71D179DAD9E817FE%2Fimage-dimensions%2F490x562%3Fv%3Dv2%22%20width%3D%22490%22%20height%3D%22562%22%20role%3D%22button%22%20title%3D%22Michelle_Wu_4-1654164483817.png%22%20alt%3D%22Michelle_Wu_4-1654164483817.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%205%20Diagramma%20schematico%20dell'analisi%20a%20fattore%20singolo%20di%20variabili%20continue%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIl%20risultato%20dell'output%20%C3%A8%20mostrato%20nella%20Figura%206.%20Dalla%20figura%20si%20pu%C3%B2%20vedere%20che%20esiste%20una%20relazione%20lineare%20negativa%20tra%20et%C3%A0%20e%20punteggio%20di%20salute%20fisica.%20Dai%20risultati%20del%20test%20statistico%2C%20la%20relazione%20lineare%20tra%20et%C3%A0%20e%20punteggio%20di%20salute%20fisica%20%C3%A8%20statisticamente%20significativa%20al%20livello%20del%20test%20di%200%2C05%20(P%3D0%2C0275).%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Michelle_Wu_5-1654164483822.png%22%20style%3D%22width%3A%20352px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_5-1654164483822.png%22%20style%3D%22width%3A%20352px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_5-1654164483822.png%22%20style%3D%22width%3A%20352px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_5-1654164483822.png%22%20style%3D%22width%3A%20352px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_5-1654164483822.png%22%20style%3D%22width%3A%20352px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42905i7A694EAED8A3A9C4%2Fimage-dimensions%2F352x602%3Fv%3Dv2%22%20width%3D%22352%22%20height%3D%22602%22%20role%3D%22button%22%20title%3D%22Michelle_Wu_5-1654164483822.png%22%20alt%3D%22Michelle_Wu_5-1654164483822.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%206%20Risultati%20dell'analisi%20a%20fattore%20singolo%20di%20variabili%20continue%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--1847625444%22%20id%3D%22toc-hId--1826588415%22%20id%3D%22toc-hId--1826588415%22%20id%3D%22toc-hId--1826588415%22%20id%3D%22toc-hId--1826588415%22%3E%3CFONT%20size%3D%224%22%3E%3CSTRONG%3EVariabili%20categoriali%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FH3%3E%0A%3CP%3EPer%20le%20variabili%20categoriche%2C%20prendi%20come%20esempio%20il%20consumo%20di%20alcol%2C%20fai%20clic%20sulla%20freccia%20rossa%20verso%20il%20basso%20sul%20lato%20sinistro%20di%20%22...Analisi%20a%20fattore%20singolo%22%20%E2%86%92%20seleziona%20%22Analisi%20delle%20medie%2FAnalisi%20delle%20variazioni%2FMerged%20t%22%20(Figura%207).%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Michelle_Wu_6-1654164483825.png%22%20style%3D%22width%3A%20412px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_6-1654164483825.png%22%20style%3D%22width%3A%20412px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_6-1654164483825.png%22%20style%3D%22width%3A%20412px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_6-1654164483825.png%22%20style%3D%22width%3A%20412px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_6-1654164483825.png%22%20style%3D%22width%3A%20412px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42906i27E11C4A00558FDD%2Fimage-dimensions%2F412x504%3Fv%3Dv2%22%20width%3D%22412%22%20height%3D%22504%22%20role%3D%22button%22%20title%3D%22Michelle_Wu_6-1654164483825.png%22%20alt%3D%22Michelle_Wu_6-1654164483825.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%207%20Diagramma%20schematico%20dell'analisi%20univariata%20delle%20variabili%20categoriali%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20risultati%20dell'output%20sono%20mostrati%20nella%20Figura%208.%20I%20risultati%20del%20test%20t%20e%20dell'ANOVA%20a%20fattore%20singolo%20sono%20riportati%20anche%20nei%20risultati%20e%20i%20risultati%20dei%20due%20sono%20coerenti.%20I%20risultati%20hanno%20mostrato%20che%20la%20relazione%20tra%20consumo%20di%20alcol%20e%20punteggio%20di%20salute%20fisica%20non%20era%20statisticamente%20significativa%20(P%3D0%2C8871).%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Michelle_Wu_7-1654164483831.png%22%20style%3D%22width%3A%20318px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_7-1654164483831.png%22%20style%3D%22width%3A%20318px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_7-1654164483831.png%22%20style%3D%22width%3A%20318px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_7-1654164483831.png%22%20style%3D%22width%3A%20318px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_7-1654164483831.png%22%20style%3D%22width%3A%20318px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42907iDC14C80AFF110DFB%2Fimage-dimensions%2F318x544%3Fv%3Dv2%22%20width%3D%22318%22%20height%3D%22544%22%20role%3D%22button%22%20title%3D%22Michelle_Wu_7-1654164483831.png%22%20alt%3D%22Michelle_Wu_7-1654164483831.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFigura%208%20Risultati%20a%20fattore%20singolo%20di%20variabili%20categoriali%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EVedendo%20questo%2C%20potresti%20chiedere%3A%20nel%20caso%20di%20molte%20variabili%20indipendenti%2C%20ciascuna%20variabile%20indipendente%20deve%20operare%20%22linea%20di%20adattamento%22%20o%20%22analisi%20media%2Fvariazione%2Ft%20unita%22%2C%20il%20processo%20sar%C3%A0%20macchinoso%3F%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EJMP%3C%2FSTRONG%3E%3CSTRONG%3E%20C'%C3%A8%20un%20modo%20conveniente%20per%20risolvere%20questo%20problema%20in%20%2C%20che%20pu%C3%B2%20visualizzare%20molto%20rapidamente%20i%20risultati%20dei%20test%20statistici%20di%20tutte%20le%20variabili%20indipendenti%3C%2FSTRONG%3E%20.%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3Eper%3CSTRONG%3E%20Per%20variabili%20continue%2C%20premere%20prima%3C%2FSTRONG%3E%3CSTRONG%3E%20Ctrl%3C%2FSTRONG%3E%3CSTRONG%3E%20chiave%3C%2FSTRONG%3E%20%2C%20quindi%20fare%20clic%20sulla%20freccia%20rossa%20rivolta%20verso%20il%20basso%20sul%20lato%20sinistro%20di%20%22Binary%20Fitting%22%20di%20qualsiasi%20variabile%20indipendente%20%E2%86%92%20selezionare%20%22%3CSTRONG%3E%20Linea%20adatta%3C%2FSTRONG%3E%20%E2%80%9D%2C%20che%20pu%C3%B2%20realizzare%20l'output%20dei%20risultati%20dell'analisi%20univariata%20di%20tutte%20le%20variabili%20continue.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3Eper%3CSTRONG%3E%20Variabili%20categoriali%3C%2FSTRONG%3E%20%2CLo%20stesso%20con%3CSTRONG%3E%20premere%20prima%3C%2FSTRONG%3E%3CSTRONG%3E%20Ctrl%3C%2FSTRONG%3E%3CSTRONG%3E%20chiave%3C%2FSTRONG%3E%20%2C%20quindi%20fai%20clic%20sulla%20freccia%20rivolta%20verso%20il%20basso%20rossa%20a%20sinistra%20di%20qualsiasi%20variabile%20categoriale%2C%3CSTRONG%3E%20scegliere%3C%2FSTRONG%3E%3CSTRONG%3E%20%22%3C%2FSTRONG%3E%3CSTRONG%3E%20media%3C%2FSTRONG%3E%3CSTRONG%3E%20%2F%3C%2FSTRONG%3E%3CSTRONG%3E%20Analisi%20della%20varianza%3C%2FSTRONG%3E%3CSTRONG%3E%20%2F%3C%2FSTRONG%3E%3CSTRONG%3E%20combinato%3C%2FSTRONG%3E%3CSTRONG%3E%20T%3C%2FSTRONG%3E%3CSTRONG%3E%20%22%3C%2FSTRONG%3E%20%2C%20che%20pu%C3%B2%20realizzare%20l'output%20dei%20risultati%20dell'analisi%20univariata%20di%20tutte%20le%20variabili%20categoriali.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EQuanto%20sopra%20%C3%A8%20l'analisi%20a%20fattore%20singolo%20basata%20su%20JMP%20per%20ottenere%20tutte%20le%20variabili%20indipendenti%20in%20un%20momento%20condiviso%20oggi.%20Quindi%20introdurremo%20come%20eseguire%20l'analisi%20multivariata%20della%20regressione%20lineare%20in%20JMP.%20Rimani%20sintonizzato!%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26gt%3B%26gt%3B%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fzh_tw%2Flearning-library%2Ftopics%2Fmultivariate-methods%2Ffactor-analysis.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3E%20Ulteriori%20informazioni%20sull'analisi%20multivariata%20di%20JMP%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fzh_tw%2Fdownload-jmp-free-trial.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Michelle_Wu_8-1654164483836.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_8-1654164483836.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_8-1654164483836.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_8-1654164483836.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Michelle_Wu_8-1654164483836.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42908i961EB96A8F39A0F4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Michelle_Wu_8-1654164483836.png%22%20alt%3D%22Michelle_Wu_8-1654164483836.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EArticoli%20consigliati%20per%20l'analisi%20statistica%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2F%25E5%25A6%2582%25E4%25BD%2595%25E5%259C%25A8JMP%25E4%25B8%25AD%25E9%2580%25B2%25E8%25A1%258C%25E7%259B%25B8%25E9%2597%259C%25E5%2588%2586%25E6%259E%2590-Correlation-Analysis%2Fba-p%2F468357%3FtrMode%3Dsource%22%20target%3D%22_blank%22%3ECome%20eseguire%20l'analisi%20di%20correlazione%20(analisi%20di%20correlazione)%20in%20JMP%3F%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2F%25E6%25A8%25A3%25E6%259C%25AC%25E6%2595%25B8%25E6%2584%2588%25E5%25A4%259A%25E6%2584%2588%25E5%25A5%25BD%25E5%2597%258E-%25E6%25A8%25A3%25E6%259C%25AC%25E6%2595%25B8%25E8%2588%2587power%25E5%2580%25BC%25E7%259A%2584%25E8%25A8%2588%25E7%25AE%2597%2Fba-p%2F435818%3FtrMode%3Dsource%22%20target%3D%22_blank%22%3EMaggiore%20%C3%A8%20la%20dimensione%20del%20campione%2C%20meglio%20%C3%A8%3F%20Calcolo%20del%20numero%20di%20campioni%20e%20del%20valore%20di%20potenza%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2F%25E8%25AA%258D%25E8%25AD%2598%25E5%258D%25A1%25E6%2596%25B9%25E6%25AA%25A2%25E5%25AE%259A-%25E5%2588%2586%25E9%25A1%259E%25E8%25B3%2587%25E6%2596%2599%25E7%25B5%2584%25E9%2596%2593%25E6%25AF%2594%25E8%25BC%2583%25E7%259A%2584%25E5%2588%2586%25E6%259E%2590%25E7%25A5%259E%25E5%2599%25A8%2Fba-p%2F444022%3FtrMode%3Dsource%22%20target%3D%22_blank%22%3EConoscere%20il%20test%20chi-quadro%3A%20un%20artefatto%20analitico%20per%20il%20confronto%20tra%20gruppi%20di%20dati%20classificati%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2F%25E5%258D%25A1%25E6%2596%25B9%25E6%25AA%25A2%25E5%25AE%259A%25E7%259A%2584%25E5%25BB%25B6%25E4%25BC%25B8-%25E7%25AD%2589%25E7%25B4%259A%25E8%25B3%2587%25E6%2596%2599%25E7%25A7%25A9%25E5%2592%258C%25E6%25AA%25A2%25E5%25AE%259A-%25E8%25B6%25A8%25E5%258B%25A2%25E5%258D%25A1%25E6%2596%25B9%25E5%2592%258C%25E9%2585%258D%25E5%25B0%258D%25E5%258D%25A1%25E6%2596%25B9%2Fba-p%2F444038%22%20target%3D%22_blank%22%3EEstensioni%20al%20test%20del%20Chi-quadrato%3A%20test%20della%20somma%20dei%20ranghi%20per%20dati%20di%20rango%2C%20chi-quadrato%20di%20tendenza%20e%20chi-quadrato%20accoppiato%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2F%25E8%25AE%258A%25E7%2595%25B0%25E6%2595%25B8%25E5%2588%2586%25E6%259E%2590-ANOVA-%25E8%2588%2587%25E5%2585%25A9%25E5%2585%25A9%25E6%25AF%2594%25E8%25BC%2583%25E7%259A%2584%25E6%2580%259D%25E8%2580%2583%25E8%2584%2588%25E7%25B5%25A1%25E8%2588%2587%25E5%2588%2586%25E6%259E%2590%25E6%2596%25B9%25E6%25B3%2595%2Fba-p%2F421202%3FtrMode%3Dsource%22%20target%3D%22_blank%22%3EAnalisi%20della%20varianza%20(ANOVA)%20e%20confronto%20a%20coppie%20e%20metodi%20di%20analisi%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ELink%20originale%3A%3CA%20href%3D%22https%3A%2F%2Fmp.weixin.qq.com%2Fs%2FuHau9nfIKPAmk9YaPoAb5Q%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20https%3A%2F%2Fmp.weixin.qq.com%2Fs%2FuHau9nfIKPAmk9YaPoAb5Q%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-498289%22%20slang%3D%22zh-TW%22%3E%3CP%3E%3CSTRONG%3EPrima%20di%20condurre%20un'analisi%20multivariata%20di%20regressione%20lineare%2C%20%C3%A8%20spesso%20necessario%20condurre%20prima%20un'analisi%20univariata.%3C%2FSTRONG%3E%20.%20Tuttavia%2C%20l'analisi%20a%20fattore%20singolo%20della%20maggior%20parte%20delle%20operazioni%20software%20comunemente%20utilizzate%20%C3%A8%20al%20momento%20ingombrante%20e%20l'analisi%20a%20fattore%20singolo%20di%20pi%C3%B9%20variabili%20indipendenti%20deve%20essere%20sostituita%20continuamente%20per%20ripetere%20l'operazione.%20L'articolo%20di%20oggi%20%C3%A8%20quello%20di%20condividere%20come%20utilizzare%20JMP%3CSPAN%3E%20Completa%20un'analisi%20univariata%20multivariata%20una%20tantum.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-498289%22%20slang%3D%22zh-TW%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAnalisi%20e%20modellazione%20dei%20dati%20di%20base%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
JMP_Taiwan
Level VI
如何使用JMP一次完成多變量的單因子分析
在瞭解如何在JMP進行數據清洗、開始基礎統計分析。本文以及後面的幾篇文章中,我們將分別對線性迴歸的分析過程逐一展開介紹。
在進行線性迴歸多因素分析前,往往需要先進行單因素分析。但是,目前常用的大多數軟體操作單因素分析比較繁瑣,需要不斷替換自變量來重複操作,才能進行多個自變量的單因素分析。
然而,在JMP軟體中可以一次性實現全部自變量的單因素分析。今天的文章就要來分享如何透過JMP完成一次性多變量的單因子分析。
為什麼要做線性迴歸?
相比前面介紹的僅含一個組別變量的單因素分析,多因素分析在實際中更為常見,因為絕大多數的結局都不止受一個因素影響。如比較兩種不同藥物治療糖尿病的療效,即使兩組間療效有差異,也未必能歸因到藥物因素,因為像BMI、血壓、飲食等諸多因素也會同時影響到藥物治療的效果,如果這些因素在兩組間不均衡,就會影響到藥物的評價效果。因此實際中我們經常要用到多因素分析。
我們通常說的「校正」年齡、性別等因素的影響,或吸煙是肺癌的「獨立預後因素」,這些指的是多因素分析。線性迴歸常用於定量結局的多因素分析,主要用於描述1個或多個自變量與定量結局的線性關係。當我們想針對某定量結局進行危險因素探索,通常首先會考慮線性迴歸,如果線性迴歸不合適,再考慮其它替代方法。
線性迴歸的單因素分析
所謂單因素分析,也就是每次做迴歸都先放入1個自變量,觀察每一自變量與應變量的關係。
目前很多統計軟體做單因素分析時,只能放入一個自變量,然後做出結果;如果要看另一個自變量的效應,則需要返回重新再操作一次。
試想如果有20個自變量,就需要來回反覆做20次相同的工作。這一過程非常繁瑣也耗時,JMP軟體則提供了一次性實現所以自變量的單因素分析的工具
以圖1的數據為例,探索軀體健康評分的可能影響因素。
圖1 範例數據(部分展示)
在JMP中依次點擊「分析」菜單→「以X擬合Y」(圖2),在彈出的對話框中將軀體健康評分導入「Y,響應」,將全部自變量導入「X,因子」(圖3)。
圖2「以X擬合Y」的操作示意圖第一步
圖3「以X擬合Y」的操作示意圖第二步
默認輸出結果如圖4所示(僅展示了3個自變量,其餘省略),頁面上僅呈現每個自變量與應變量的散點圖。
圖4 「以X擬合Y」的輸出結果
如果要查看各個自變量的單因素分析的檢定結果,則需在JMP中進行後續的一些操作。需要注意的是,連續變量和分類變量的操作步驟不同。
連續變量
對於連續變量,以年齡為例,點擊結果界面中「二元擬合」左側的紅色向下箭頭→選擇「擬合線」(圖5)。
圖5 連續變量的單因素分析操作示意圖
輸出結果如圖6所示,從圖中可以看出,年齡與軀體健康評分呈負向線性關係。從統計學檢定結果來看,年齡與軀體健康評分線性的關係在0.05的檢定水準上具有統計學意義(P=0.0275)。
圖6 連續變量的單因素分析結果
分類變量
對於分類變量,以飲酒為例,點擊「……單因子分析」左側的紅色向下箭頭→選擇「均值/變異數分析/合併的t」(圖7)。
圖7 分類變量的單因素分析操作示意圖
輸出結果如圖8所示,結果中同時給出了t檢定和單因素變異數分析的結果,兩者結果一致。結果顯示飲酒與軀體健康評分的關係不具有統計學意義(P=0.8871)。
圖8 分類變量的單因素結果
看到這裡,你可能會問:在自變量很多的情況下,每個自變量都要操作「擬合線」或「均值/變異數分析/合併的t」,過程會不會很繁瑣?
JMP中有一種便捷的方式用於解決此問題,能夠非常快速地顯示出全部自變量的統計檢定結果
  • 對於連續變量,先按ctrl,然後點擊任意一項自變量其「二元擬合」左側的紅色向下箭頭→選擇「擬合線」,可實現所有連續變量的單因素分析結果的輸出。
  • 對於分類變量,同樣是先按ctrl,然後點擊任意一項分類變量左側的紅色向下箭頭,選擇均值/變異數分析/合併的t,可實現所有分類變量的單因素分析結果的輸出。
以上就是今天分享的基於JMP一次性實現全部自變量的單因素分析。之後我們將介紹如何在JMP中開展線性迴歸的多因素分析。敬請期待!
>> 深入瞭解 JMP 多變量分析
統計分析推薦文章:
原文連結: https://mp.weixin.qq.com/s/uHau9nfIKPAmk9YaPoAb5Q
Last Modified: Jun 8, 2022 12:19 AM
