  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
Getting Started with JMP
Getting Started with JMP: On Demand Course
Started ‎04-07-2023 by
Modified ‎05-15-2025 by
Click the Begin! button below to start, or click Resume to return to where you left off. You can watch the videos in order, or jump to specific topics using the navigation pane on the left.
Download the Getting-Started-data.zip file linked above to follow along with the demonstrations. The Big Class.jmp data file is used in the introductory videos.
In these videos you'll learn about:
  • the four components of the JMP data table
  • manipulating and managing data by recoding data, adding column properties, and creating formulas
  • summarizing and joining data tables
  • importing data into JMP
  • using JMP analysis and graphing platforms such as Distribution and Graph Builder
  • saving scripts as part of a data table file, so you can easily recreate your analyses and share them with colleagues.
Erratum     In the video “Creating a Summary Table and Changing Column Names,” the narrator says that linking the Summary table means changes in the original table will be reflected in the Summary table. Unfortunately, that’s not the case! (It is true for linked Subset tables, though.) Changes to the data in the original table will result in the Summary table being disassociated from it. We apologize for the error!
Comments
Amazing format: Short videos, great explanations, question to ensure that the content can be applied. Thank you very much for sharing. Could this format be useful for you?
 @Aziza @Steffen_Bugge @JohannD @shoffmeister @Ole_Luehn @Andreas_Büchse @Will_Penland @gerd @Peter_Vogel @Georg
Aziza
Excellent! Thanks for sharing!
MaanasaT
Love this format of Getting Started, especially the practice problems! Thank you for this!
jpol
Hi,
I am unable to download the Excel file "Product and Supplier Info.xlsx"  from the Resources menu.
When I attempt to do so I get the "Not Found" error message.
Is the link broken or is there some other issue?
Thanks,
Philip
jpol
jthi  provided another link where the Excel file is located:
Getting Started with JMP Journal and Data - JMP User Community
@jpol Thanks.
Wish I would have known about this sooner. @monique_lander were you aware of this resource?
Is there a cert at the end of the introductory module?
anis72
it is working now . thanks
@anis72 what is not working?  The files are downloadable on this page and also here: https://community.jmp.com/t5/Learning-Center/Getting-Started-with-JMP-Journal-and-Data/ta-p/512472
And the video is working  on Chrome and Edge.  If you send details I can try to help.
StellaDiva
Where are the Companies.jmp and TeamResults.xls files?
SrClean
I cannot see the training video or any "begin" button. I get this:
ryandewitt
@SrClean Thank you, and I believe this is resolved.  Thank you for taking the time to comment on this, and please let us know if we can help with anything else.
-rd
Where can I find companies.jmp ??
Hi @Probabilities   All the sample files, including companies.jmp are in your JMP Program Files, for Example  C:\Program Files\JMP\JMP\18\Samples\Data and you can access them directly from JMP:
Thank you @gail_massari :)
