Click the Begin! button below to start, or click Resume to return to where you left off. You can watch the videos in order, or jump to specific topics using the navigation pane on the left.
Download the Getting-Started-data.zip file linked above to follow along with the demonstrations. The Big Class.jmp data file is used in the introductory videos.
In these videos you'll learn about:
- the four components of the JMP data table
- manipulating and managing data by recoding data, adding column properties, and creating formulas
- summarizing and joining data tables
- importing data into JMP
- using JMP analysis and graphing platforms such as Distribution and Graph Builder
- saving scripts as part of a data table file, so you can easily recreate your analyses and share them with colleagues.
