narens13
text to columns in JMP similar to excel
is there any way I can do text to columns in JMP as in excel
thanks
7 REPLIES 7
pmroz
If you are referring to Excel's ability to read in delimited text files, JMP can do the same thing.  Click on File > Open and select Files of type: Text Files (*.txt; *.csv; *.dat; *.tsv).  Your best bet is to use the option Data with preview.  This will bring up a screen allowing you to specify all kinds of options, such as fixed width fields or delimited, the delimiter to use (if delimited fields), end of field character, etc.
narens13
I want one column to be separated into two coulmns based on the delimiter
Jeff_Perkinson
Try this add-in.
Text to Cols
-Jeff
-Jeff
narens13
is there anyway i can use the same functionality of this addin in JMP 8
Jeff_Perkinson
There'a .jmpmenu file version of it.
Make Columns from Text
It's a .jmpmenu file. You'll need to use Edit->Customize->Menus and Toolbars and then use the red triangle menu to "Import Menu Archive".
-Jeff
-Jeff
narens13
When i insert the jmpmenu in JMP 8..i get the following error
Error in menu file.  Error: Unable to insert into menu.  Unable to find menu: EXTRAS
Thanks
Jeff_Perkinson
Sorry. I forgot that it relied on the Extras menu.
Here's the link for that:
Empty Extras Menu Archive
-Jeff
-Jeff
