narens13
text to columns in JMP similar to excel
is there any way I can do text to columns in JMP as in excel
thanks
pmroz
If you are referring to Excel's ability to read in delimited text files, JMP can do the same thing.  Click on File > Open and select Files of type: Text Files (*.txt; *.csv; *.dat; *.tsv).  Your best bet is to use the option Data with preview.  This will bring up a screen allowing you to specify all kinds of options, such as fixed width fields or delimited, the delimiter to use (if delimited fields), end of field character, etc.
narens13
I want one column to be separated into two coulmns based on the delimiter
Jeff_Perkinson
Try this add-in.
Text to Cols
-Jeff
-Jeff
narens13
is there anyway i can use the same functionality of this addin in JMP 8
Jeff_Perkinson
There'a .jmpmenu file version of it.
Make Columns from Text
It's a .jmpmenu file. You'll need to use Edit->Customize->Menus and Toolbars and then use the red triangle menu to "Import Menu Archive".
-Jeff
-Jeff
narens13
When i insert the jmpmenu in JMP 8..i get the following error
Error in menu file.  Error: Unable to insert into menu.  Unable to find menu: EXTRAS
Thanks
Jeff_Perkinson
Sorry. I forgot that it relied on the Extras menu.
Here's the link for that:
Empty Extras Menu Archive
-Jeff
-Jeff
