    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
kca
kca
Open data tables from file dialog
Is there a file open dialog box where I can select several files and have it return a list of files for my JSL script to operate on?  I would prefer to have the standard Windows one that one sees when they press File > Open in JMP.
Edit:  'Pick File' is the command I was looking for.
ms
Super User (Alumni) ms
The dialog that comes up when running Open(), or Pick File(), looks exactly like a standard File > Open dialog (at least in JMP 9 on the Mac) but it seems to be limited. In contrast to the standard open-dialog only one file can be selected in the open-dialog called from JSL.
In Mac OS X I haven't found a way to open the standard dialog from script, but it may be possible on Windows where JMP can call dll-files. I am not of much help in that area but there som amazing examples in other threads of what can be done via dll.
If you would find a way to do that, the code below can be used to get a list of the names of the last opened data tables.
nr_of_already_open_tables = N Table;
Open( );// some clever dll funcion or similar
last_opened_tables = Local( {i, d = {}},
          For( i = 1, i <= N Table() - nr_of_already_open_tables, i++,
                    d[i] = Data Table( i ) << GetName
          d;
ms
          d;
kca
kca
Thanks, MS.  You are right that even on Windows I can only select a single file.  However, it turned out that is all the functionality I need.   Your code snipet did come in quite handy after that!
