steo45
test data STDF to dispay units
i have an stdf file  from test data  im able to extract a limits table from the file. but i do not have units.
 any idea how to get the test limits units from the stdf files ??
Re: test data STDF to dispay units
What method are you using to read in the STDF files?
steo45
im using spry software quick load
You will need to contact Spry Software
http://sprysoftware.net/support/
cbaptist
Chris here from Spry Software.  What data type are you using?  For Parametric QuickLoad normally reads the limits from the STDF into Column Info, Units.  For Test Summary they should go in the "Unit" column.
If you want to talk in more detail off line, fill out our support form at https://sprysoftware.net/support/
thanks,
Chris
