Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
Valentina
sumif: count columns if they contain some character
I found a discussion from 2015 (subject "sumif") that has a very helpful script for my current task.I wrote there my question but I don't know if people who participated in that discussion can see my question.
This script I found (slightly modified) and it works great for counting columns for each row where values are "0/0" (or whatever).
dt << New Column("Sum",
    Numeric, Formula(
        Local({i = 0, n = N Col(Current Data Table()) - 1},
            Sum(Repeat({i++ ; (Column(i)[] =="0/0")}, n))
However, how to edit this script to count columns that Contain "some_character"?
I have attached a data table where the last column "Sum" has a formula and needed resulted numbers.
I have a big data table and would like to have a script for counting columns for each row with specific values (as character).
I tried to modify the script above but it doesn't work:
dt << New Column("Miss",
    Numeric, Formula(
            Sum(Repeat({i++ ; (Contains(Column(i)[],"."))}, n))
Please, help
Valentina
Re: sumif: count columns if they contain some character
Most likely your loop is reaching some column which isn't character column. This part most likely needs some modification
how it should be done is very difficult to know without any knowledge of your data. It could be just a simple modification to the -1, getting list of character columns or calculating which columns to go through by some sort of a pattern
Do you need to have a formula for this?
Valentina
Sorry, I don't understand your question.
I have a table ~500,000 rows and ~3,000 columns. I need to calculate Sum across columns that contain a dot - cant use formula. .
I want to have a script, any script that would work. I tried different approaches but none worked.   .
Valentina
This is from my log:
Column Sum Formula Interrupted
argument is wrong type at row 421001 in access or evaluation of 'Contains' , Bad Argument( Column( i )[] ), Contains/*###*/(Column( i )[], ".")
Formula evaluation errors have been ignored
Valentina
I have attached a small data table to my post. It has 3 rows and 3 cols with a header:
S1    S2    S3
0/0   ./.     0/0
0/0  0/0    0/0
The script doesn't work in this sample table
Column sum Formula Interrupted
argument is wrong type at row 1 in access or evaluation of 'Contains' , Bad Argument( Column( i )[] ), Contains/*###*/(Column( i )[], ".")
The original data table you attached wasn't like that as it has 4 columns (you cannot ignore Sum column)
Depending on your data, this is how I would do this if I were to use a Formula (most likely I would avoid that and just use a pure script solution)
dt = Open("$DOWNLOADS/sum_help_data.jmp");
dt << Delete Column("Sum");
dt << New Column("Miss", Numeric, Continuous, Formula(
	As Constant(
		cols_of_interest = Filter Each({colname}, Current Data Table() << Get Column Names("String"),
			!IsMissing(Regex(colname, "S\d"));
	Local({
		res = 0;
		For Each({colname}, cols_of_interest,
			res = res + (Contains(Column(colname)[], ".") > 0);
		res;
Valentina
Yes, it seems all data should be the same type.
Thank you - it works!
