rahulsmils
statistics summary from jmp table
Dear all,
I have a jmp data table as shown in Input data table format below with multiple columns ~50
Also the number of rows is flexible it can vary from class1 to class 100
I intend to generate a statistics summary jmp table as shown in output table format.
Right now the way I am doing this is very cumbersome as I am hard coding each column name and that occupies much of code.
Is there a quicker way at arriving at the final statistics table.
//---Input data table
			A       B		C     ..............about 50 columns
class1     21.5		54.9
class2	   22.3		65.9
class3     29.2		58.5
class4     32.1		76.1
class5     54.7		87.1
class6     23.9		89.2
//---Output desired
		Mean(of class1 to 6)    	Median(of class1 to 6)		Interquartile range(of class1 to 6)      standard deviation(of class1 to 6)   range(of class1 to 6)
A
B
C
//--Present approach----bad way: group, stack and then split----->>
		Grouped_Sum = dt <<
		Summary(
			Median(
				:Name("A"),:Name("B"),.......
			Std Dev(
			Mean(
			Interquartile Range(
			Range(
			Freq( "None" ),
			Weight( "None" )
Stack_me = Grouped_Sum <<
		Stack(
			columns(
				:Name("Median(A)"),:Name("Median(B)"),....,
				:Name("Std Dev(A)"),:Name("Std Dev(B)"),
				:Name("Interquartile Range(A)",),:Name("Interquartile Range(B)"),
			Source Label Column( "Label" ),
			Stacked Data Column( "Data" ),
			Drop All Other Columns( 1 ),
			Output Table( "stacked_data" )
Final = Stack_NMT << Split(
	Split By( :handle ),
	Split( :Data ),
	Group( :something ),
	Remaining Columns( Drop All )
Thanks in advance.
Re: statistics summary from jmp table
2 responses
1. You should be able to go directly to the ouput display you want if you use
     Analyze==>Tabulate
2. You don't need to do any typing of the input for the approach you are taking.  If you just interactively run the summary, and create the summary data table, if you go to the table panel on the upper left side of the output data table, it will have a selection called "Source" and if you edit it, it has all of the code already generated that was used to create the summary output.  You can do the same for the Stack step and the Split step.  All you need to do is the copy and paste the JSL
2 responses
     Analyze==>Tabulate
rahulsmils
Thanks Jim. Tabulate works for me perfectly.
Is there a way I can send output table of tabulate to a jmp data table ?
Yes, under the red triangle, is an option "Make into Data Table".    You need to get in the habit of exploring all of the red triangles etc.
rahulsmils
Thanks so much. I also figured it out by myself just now :)
