rahulsmils
Sorting bivariate plots by P-value
I seek another advice on plotting and sorting multiple bivariate plots.
I am creating a bivariate fit of about 40 y variables to 10 different x variables[ each y and x pair has separate figure].
I do a linear fit on each one of them [regression] which is simple part.
Subsequently, I wish to arrange the plots in order of increasing p-value of the fit, in a journal so the plots with the best fit/correlation appear first.
Any suggestions to accomplish this will help.
Thanks !
Re: Sorting bivariate plots by P-value
Go to
     Analyze==>Screening==Response Screening
Run the platform.  It generates a data table with all of the p-values.
Sort the p-values, descending
Then select all of the rows that you want to plot out in order
Finally, go to the embedded script "Fit Selected Items, and run the script.  It will put all of the analyses into new window, sorted as you want
Go to
