Thank you so much for reply me!
I read the JMP documentation, section prediction profiler Options. And I found that "Output random table" is the filtered Montecarlo technique, while the "Simulation" is just a Montecarlo simulation that uses the random noise.
I do not know the difference between the two techniques and what method is better, I have to study better this two difference. If you have some advice , it is well appreciated. However, I have checked that Montecarlo simulation takes more time than filtered Montecarlo technique.
I have to do this in the profile of the neural network. Therefore I thought that it could be a Hybrid ANN-Montecarlo simulation.
To help to understand:
For random table,
1. I selected the option neural
2. I clicked the red triangle in the model
3. I clicked the option Prediction profile
4. I clicked the red triangle in prediction profile.
5. I selected Output random tables.
For simulation, I performed the same procedure, but instead of clicking the "Output random tables", I selected the option "simulator". I clicked the red triangle and selected "Simulation Experiment".
I adjusted the noise in the interactive cells and selected the random variable.
