Level XIII
robust column reference
After a few minutes coding with JSL, users wonder about strange objects like :sex in
x = :sex
Expert users have some experience with such column references and use them all the time.
But what is :sex ? Is  dt:sex  more robust? Where do I find a documentation ?
Let's collect and share some insights.
my 5 cents:
14 REPLIES 14
Level XIII
Re: robust column reference
Take home message:
With the learning from
myList2 = Eval List({Name Expr(As column(:name)),Name Expr(As column(:sex)),Name Expr(As column(:age))});
we can convert any list provided by JMP into a robust list of columns via
ColNames = dt << get column names;
colList = Transform Each({col}, ColNames, Name Expr(As Column (col)));
Byron_JMP
my approach is much more simplistic. I'm careful to build my list of columns for the specific purpose I have in mind. Sometimes I have multiple lists of the columns in different formats.
text = dt << Get Column Names();
quote = dt << Get Column Names( String );
colformat = dt << get column reference();
show(text, quote, colformat);
which returns:
text = {name, age, sex, height, weight};
quote = {"name", "age", "sex", "height", "weight"};
colformat = {Column("name"), Column("age"), Column("sex"), Column("height"), Column("weight")};
one of the three generally works, even if I have to resort to eval(parse())
Level XIII
Basically, I am with you. After taking some precaution, names are not very dangerous:
One can argue if it's clever to rename a column after creating a column list - and then to wonder/complain that the old name doesn't work anymore.
And when working with two tables, one has to ensure that the correct data table is the current data table().
Same with column names:
One can assume that JMP handles column names correctly -  even with capital letters and spaces. [find the link]
Or one can be cautious and follow some rules. (no collisions of names, variables and column names; caution with space, ...) and most of the day live safe without issues.
Level XIII
Hi @Byron_JMP , to be picky ...
get column names() returns a list of  names ; )
Level XIII
Important finding - I just edited one of the first posts!
I hope my thoughts are understandable - at least to some users like @Craige_Hales .
I guess, these users will also share my astonishment/enlightenment/joy and/or :help out by confirming that it's like this, provide an explanation, or make corrections.
Up to now I thought about As Column(col) as a way to retrieve the value of the current row - especially compared to Column(col) for "column access"  (you know, like in Column(col) << get name).
With the inverse implication:
Whenever I use :col for anything other than the "value of the current row",then when I want to replace it with a variable, then I don't have to use As column(),  I have to use the other one instead, namely Column(col).
[I must admit that I was also puzzled by the name:
As column() - for the function that does the inverse, get not the column, but the value of the current row? you are kidding?
another thought:
If As Column(col) works in such cases, then it's just because JMP corrects the error of the user automatically - or because of an esoteric effect that everybody uses but nobody explains - like in Name expr(As column(col))
So, I feel very comfortable now after finding out:  ....]
This interpretation must be wrong. It is triggered by an automatism in JMP which might follow the idea:
As column(col)gives access to the column.
If it it evaluated (Eval(As Column() ...))i, it converts to  column(col)[] aka column(col)[row()] which can be used to access the value of the current row.
If it is not evaluated, but used in other functions, it gives access to the column.
Why do I think that it's like this?
Names Default to Here(1);
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
row()=10;
Lag(:height);                           // 60
Show(lag(Column ("height"),1));         // Column("height") !!!
Show(lag(As Column ("height"),1));     // 60 !!!
Col Mean(:height);                             // 6255
Col Mean(:height, :age);                       // 60.285...
Show(Col Mean(Column ("height")));             // 62.55 (why does it work? another automatism because it is used so often?)
Try(Show(Col Mean(Column ("height"), :age)),Print(exception_msg)); //  !!!
Show(Col Mean(As Column ("height"), :age));    // 60.285...
[ triggered by https://community.jmp.com/t5/Discussions/Using-numeric-objects-in-a-column-equation/m-p/903939/highl... ]
