hogi
Level XIII
robust column reference
After a few minutes coding with JSL, users wonder about strange objects like :sex in
x = :sex
Expert users have some experience with such column references and use them all the time.
But what is :sex ? Is  dt:sex  more robust? Where do I find a documentation ?
Let's collect and share some insights. Please add your thoughts and correct my posts if you find errors ...
my 5 cents:
17 REPLIES 17
hogi
Level XIII
Re: robust column reference
In JSL, one and the same column reference :sex (or dt:sex) can be used in two ways:
# 1) as a reference to a column
:sex << get name;
Data Table( "Big Class Families" ) << Distribution(	Nominal Distribution( Column( :sex ) ));
 ... and #2
 to retrieve the entry of the current row in this column, like in:
[edit]: no!
"To be used in column formulas - and can usually be thought of as the 'value of the current row'.
But there are many more cases which also require this type of :sex
row()=5;
s=:sex; // value of the current row
// other cases:
lag(:sex,1); // value of the previous row
Col Mean(:height, :age)); // mean :height of rows with same :age
Please note: in column formulas, the following approaches are equivalent
new column("s", formula (:sex));
new column("s", formula (:sex[]));
new column("s", formula (:sex[row()]))
To create such an object from a string, one has 2 options:
column name = "sex";
col= Column (column name); // for the first one (accessing the column)
val = As Column (column name) // for the second one (accessing the column in formulas)
Actually, there is a very cool 3rd option, which I learned from @jthi :
the universal column reference = Name Expr(As Column(column name))
it can be use like :sex for both approaches. referencing the column and accessing the entry of the current row.
Column() vs As Column() vs datable:column vs dt:As name("column")
hogi
Level XIII
:sex looks fragile - what happens when the user changes the column name?
Names Default to Here(1);
x = Name Expr(As column("name"));
Show(Name Expr(x)); // : name
:name << set name("The name");
Show(Name Expr(x)); // :The name
wow, great! Not fragile at all!
hogi
Level XIII
And when the user changes the data table?
Show(Name Expr(x));
x[1] = "Marker";
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
Show(Name Expr(x));
Show(x[1])
The innocent :sex even knows which data table it actually belongs to. Wonderful!
hogi
Level XIII
Now, let's go from 1 column to 3 columns:
myList1 = {:name,:sex,:age};
A very complicated and useless way to create this list is:
myList2 = Eval List({Name Expr(As column(:name)),Name Expr(As column(:sex)),Name Expr(As column(:age))});
hogi
Level XIII
useless?
you already notice the big difference when you try to execute the above code without a
The first line does not care that there is no open data table. When you run the second line, JMP will complain:
Even better: when the list is created with the second approach, the column references are very robust.
Independent of the current data table, JMP will go to dt and and use the columns from there:
dt2= Open( "$SAMPLE_DATA/Big Class Families.jmp" );
dt << Select Rows( [1] ) << Delete Rows; // now dt starts with Louise - there is no Katie anymore!
Show(Eval List(myList1), // Katie? why Katie!!!
Eval List(myList2)); // Louise -> works!
How does it work?
Show(Type(myList1[1]), Type(myList2[1]))
provides more insight:
The simple list (myList1) contains "Names" , *)
the complicated list (myList2) contains "Columns" **)
*) When a name is evaluated, JMP follows a specific rule to determine what this name means:
 https://www.jmp.com/support/help/en/19.0/#page/jmp/rules-for-resolving-names.shtml
Among the roles, JMP will search for a column in the current data table (dt2).
**) For a  Column, JMP just has to go to THE data table ("dt") and access the column.
Very robust!
hogi
Level XIII
Name Expr(As column(:col))
is soooo cool!
Byron_JMP
The Column() works in a lot of situations and its pretty flexible with respect to the format of the column name.
Distribution(
	Continuous Distribution( Column( :Random Normal )),
	Continuous Distribution( Column( "Random Normal" )),
	Continuous Distribution( Column( :"Random Normal"n )),
	Continuous Distribution( Column( "Random Normal"n )),
	 Process Capability( 0 ) )
hogi
Level XIII
Distribution(
Hi @Byron_JMP , one can have a lot of fun with Column() inside distribution()
Distribution(Continuous Distribution( Column( :height )) );
Distribution(Continuous Distribution( Column( "height")) );
A Column reference, a name - even a String!   Everything works.
... till you try to use a  column that is defined outside of the Distribution command:
col = Column("height");
Show(col); // shows: it's a column
Distribution(Continuous Distribution(col));
Distribution(Continuous Distribution(Eval(col)));
Distribution(Continuous Distribution(Name Expr(col)));
One can try all such esoteric "Let's just try all of them - one of them should work"-Expression Handling-Tricks, none of them works!
Always the same hint, but what does it mean?!?
The solution is very easy - but it can take hours when you search for it at the wrong spot.
:backhand_index_pointing_down:
View more...
Column( :height ) inside Continuous Distribution() looks like Column("height") in
But it is a named argument - like Formula() in New Column(Formula(...)).
So the "obvious" solution is: keep the name of the named argument and place the column inside:
Distribution(Continuous Distribution(Column(col)));
hogi
Level XIII
interesting: when asked for lists of columns, JSL functions return lists of names, not lists of  columns!
colList = Eval List({Name Expr(As column("sex"))});
write(Name Expr(colList[1]), " is a  ", // :sex
Type(Name Expr(colList[1])), "\!n"); // Column -> universal & robust
selectedCols = dt << select columns (:sex) << get selected columns;
write(Name Expr(selectedCols[1])," is a ", // : sex
Type(Name Expr(selectedCols[1])), "\!n"); // Name -> fragile
dt << Group Columns(Item Range( :sex, :height ),"myColGroup");
colsFromColumnGroup = dt << get column group("myColGroup");
Write(Name Expr(colsFromColumnGroup[1]), " is a  ", // :sex
Type(Name Expr(colsFromColumnGroup[1])), "\!n"); // Name -> fragile
The difference between  Get Column Names() and Get Column References():
ColNames = dt << get column names; // default setting: returns names, not Strings
Write(Name Expr(ColNames[3]), " is a  ", // sex (more or less the same as :sex)
Type(Name Expr(ColNames[3])), "\!n"); // Name -> fragile
ColRefs = dt << get column references;
Write(Name Expr(ColRefs[3]), " is a  ", // Column("sex"
Type(Name Expr(ColRefs[3])), "\!n"); // Column -> robust, but not :sex, see below
and now let's play with the column and then ask for the value of  :sex in row 1:
//hide the column
:sex <<  set name("hidden");
// who finds it?
row()=1;
Try(Show(Eval(ColList[1])), print(exception_msg));
Try(Show(Eval(colsFromColumnGroup[1])), print(exception_msg));
Try(Show(Eval(selectedCols[1])), print(exception_msg));
Try(Show(Eval(ColNames[3])), print(exception_msg));
Try(Show(Eval(ColRefs[3])), print(exception_msg));
